civic doesnt have Neutral.
i just installed my tranny after have an ctr lsd installed. I connected the extension change-rod & the extension rod, i have my stick in the Neutral position but when i let off the clutch the car dies. I also put it in 1 through 5 & the car dies in every gear.
I have the car on jack-stands, without both of the axles shafts install.
Where do i even start?
I don't know man sounds like the install went bad. Who installed it I would take it back to them. It seems like internally one of your gears is locked up. This could be like really bad fluid or if the fluid was filled in the cold and you added way too much but i doubt that.
i used oil Honda manual tranny fluid, i removed the 17mm bolt on the pass-side, & filled it till it started coming back out. i went back to the place who installed the differential, the builder said to put it in all the gears & see if it dies, well.... it does. just dunno what to do after that. ???????
I got oil leaking from my turbo now, i still dunno whats going on, when i get it running again, i will drive it down to the shop & have the tech look at it.
Duck Sauce
Apr 29, 2008 11:34 PM
