what flywheel for my b20v all motor build
I got a b20b with gsr head, 11:5:1 compression. should I use a stock flywheel or something different. Not sure if i'm going gsr tranny or b16, also let me know what tranny you guys on running.
i have heard a few horror stories about those two piece flywheels separating. I like to stick to a steel or chromoly flywheel just because of the durability. but hey, everyone has their own opinion!
I would like to know because I have a Fidanza LW FW and don't want to put it on my car if it's going to separate. I did a lot of reading and research before I made my purchase. I haven't read any negative articles about the 2 piece. Other than some people complaining that it is too light.
If they split apart that frequently, one would assume, they wouldn't be able to sell them as street legal units. I didn't see any "Not For Street Use" warnings on any of my Fidanza parts. I do however see a sticker that indicates that they are SFI Certified. Not sure if that means much for a street car but it must account for something.
Do you have any links to the "horror stories"? What was the cause for seperation, manufacturing defect or installer error?
i am running a act lightweight flywheel, 11lb. for a street car i think it is better to have a little more inertia. if you were boosted or drag car, then maybe the flywheel would be parasitic inertia, but in a all motor street car, it seems to benefit to having that little extra flywheel weight to carry the car into the next gear.
yeah i have had my stock flywheel come loose...lol the ring gear came loose on it and i would push start my car for a while...but that is why i got a light weight one...
I have heard of people taking some off the stock flywheel, but I don't personally like that idea. Takes away from the stability and you really couldn't take off enough to make much of a difference without making it a hazard kinda. The stock B series flywheels are 18lbs. I would recommend one that it around 10-12, less than that will make shifting tough at times. I had a 11 lb one in my integra and that was great for all motor. I am getting one around 10lbs for my del sol all motor.
if you DD the car or do alot of city driving stay away from the lighter FWs, much more of a pain in the dick to drive. a 12-13lb one is IMO the best balance of the 2.
a well known clutch company used to machine stock flywheels years ago and sell them. i have had local machine shops shave the outer of b series flywheels before, and haven't had a problem. but just the outer of the flywheel, thats where it is going to have the most effect. and also get your whole rotating assy. balanced.
