shaving head for ls/vtec
Old Aug 15, 2002 | 09:34 PM
hybridhatch90's Avatar
Default shaving head for ls/vtec
anyone know how much i can shave off of a b16 head on a b18a block with stock pistons and head gasket without having a meeting between valve and piston? and the compression ratio produced if possible.
Old Aug 15, 2002 | 10:01 PM
spettinger's Avatar
Default Re: shaving head for ls/vtec (hybridhatch90)
i think the most should ever be machined is about 40 thousandths, and only that much for resquaring. just get a mugen head gasket to up compression, don't **** with milling it too much.
Old Aug 16, 2002 | 12:47 PM
Default Re: shaving head for ls/vtec (wreckedhatch)
ttt
Old Aug 16, 2002 | 02:45 PM
speeddave's Avatar
i'm not sure of exact machining tolerances, but i would be careful. the stock b18a pistons do not have the valve reliefs that the vtec head requires. thats why guys replace the pistons w/b16/type r (well besides bumping the comp) etc.. imo just buy a set of stock bore vtec pistons. you'll have to buy cam gears anyway to adjust your setup once the head is milled.
Carlorec96
Jul 21, 2018 05:59 PM
Honda_Noob42385
Feb 26, 2009 04:52 AM
punkracer
Dec 2, 2005 08:19 AM
TriK
Jul 1, 2003 09:37 AM
lazyguy
Dec 10, 2002 07:40 PM
