Car wont Start..
Old Apr 22, 2009 | 01:23 PM
gt35rSI's Avatar
Default Car wont Start..
I have a 00 civic si and main relay i think went bad. i have an RZ 0132 laying around and wondering if anyone knows if this one will work.. It is out of an integra. thanks
Old Apr 22, 2009 | 02:24 PM
Peeonu25's Avatar
Default Re: Car wont Start..
im thinking no? their different part numbers, see how similar they look, if it plugs in try it, you might pop a fuse?
are your plugs firing? are they wet?
Old Apr 22, 2009 | 02:31 PM
gt35rSI's Avatar
the car wont even crank, car just clicks when turning key to on
Old Apr 22, 2009 | 02:35 PM
Peeonu25's Avatar
thats not your main relay, all that relay does is powers your fuel pump.
check your grounds, make sure the power wires are connected properly to the starter, check your starter fuse (99% sure there is one)
hows your battery? clean your contacts.
Old Apr 22, 2009 | 05:05 PM
fcm's Avatar
fcm
Old Fart
Although I agree that the problem is not the PGM-FI Main Relay, [main relay] the PGM-FI Main relay does not just "power the fuel pump" it is in fact two relays in one package, one is the power relay for the fuel pump the other is the power relay for the fuel injectors along with a few engine sensors and solenoids.
gt35rSI, Where is the "click" coming from, under the dash, [starter realy if it's a 5 speed] or engine bay, [starter solenoid].
As mentioned, your problem is a low batt. or a connection problem.
Question, does the car horn work properly, will it still work properly if the head lights are on? 94
reomi
Jul 28, 2008 08:47 AM
sawedoffcoupe
19
Aug 28, 2007 11:10 AM
boosted_lude
Jun 14, 2007 01:32 PM
torr
Apr 11, 2005 03:58 AM
PUSHER
Jun 21, 2004 11:21 AM
