Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
My passenger side window doesn't go up in place * Need help*
Old Apr 22, 2009 | 01:11 PM
frank358fr's Avatar
Default My passenger side window doesn't go up in place * Need help*
Hi,
I have a poblem with my new Civic 2008 EX. My passenger side window does not go up in there place. I need to push the window to the left with my hand to be cleary in there track. I looked over the forum but I found nothing for removing the plastic panel inside the car to see what was the problem. Is there anyone who know how to repair it with a DIY?.
Thank you
Frank
Old Apr 22, 2009 | 01:27 PM
Skeeter7424's Avatar
Default Re: My passenger side window doesn't go up in place * Need help*
if its an 08 take it back to the dealership and have them repair it under warrantee. there is no reason for you to pull that panel off yourself. they will take care of what needs to be done.
...skeeter...
Old Apr 22, 2009 | 03:17 PM
ChargedSI's Avatar
...skeeter...
This is good advice. If you pull the panel off yourself, they will know and could claim you were responsible for the broken window. This is what the dealer pulled on me when my door lock stopped working. I had some aftermarket speakers installed prior to the lock breaking. When I took it to the dealer to get the lock fixed, they first tried to refused coverage because "someone else" had removed the panel and been in the door. Eventually they did cover it, but it was a hassle.
Old Apr 22, 2009 | 07:08 PM
frank358fr's Avatar
The problem is that there's no warranty because its a salvage title....need help please!
Old Apr 22, 2009 | 08:05 PM
ohdannyboy73's Avatar
Before you remove the panel, make sure your window locked out isn't depressed on your driver side door.
Old Apr 23, 2009 | 05:54 AM
frank358fr's Avatar
...need help!
ENTRAPM3NT
May 23, 2013 10:54 AM
pvuchetich
Honda CR-V & Element
Jan 3, 2012 01:24 PM
JDMgunmetalCRX
Mar 31, 2009 08:50 AM
deerman2701
Nov 27, 2007 05:59 AM
4Dinsaneb16
Mar 20, 2007 01:30 PM
