b16 head help
Old Apr 22, 2009 | 11:47 AM
da1haloking's Avatar
Default b16 head help
i am plaining on building a poor mans type r with spray, i bought a fully built b16 head, but it is already tapped for lsvtec, i dont know if i can still use this head for a pmtr or i have to go lsvtec now? which one do u guys think is better??
Old Apr 22, 2009 | 12:19 PM
00Red_SiR's Avatar
All Motor Mentor
Default Re: b16 head help
how about you do some reading and research on here to determine which one is BETTER for you? Define "fully built head".
Old Apr 22, 2009 | 02:33 PM
skunk 2 valves and retainers, valve seals cams cam gears,port ploish angle job
Old Apr 22, 2009 | 04:13 PM
00Red_SiR's Avatar
All Motor Mentor
who did the "port and polish" work?
Old Apr 22, 2009 | 04:42 PM
idk bought it as is. i really just need to knwo if i can use this head to build a pmtr or i cant cause its tapped for lsvtec
Old Apr 22, 2009 | 04:59 PM
96Spec Ek's Avatar
There is a plug that goes into a oil passage hole in the head to block it off for a ls vtec since the ls block doesn't feed oil to the head. If the plug is still there simply remove it and you will be fine. Also just plug up the threaded hole where the ls/vtec oil supply line and your good.
Old Apr 22, 2009 | 05:03 PM
thanks
CRXguy_88
Jul 14, 2011 01:40 PM
Teamdiesel
Mar 7, 2010 05:47 PM
philliedawg
Nov 12, 2008 04:19 AM
BlakeJ53
Dec 28, 2006 01:34 PM
stock94
Nov 7, 2003 06:35 PM
