what guage wire to use? fuel pump.
Old Aug 15, 2002 | 09:12 PM
Mazmay's Avatar
Default what guage wire to use? fuel pump.
I'm trying to connect two wires. Went to buy a wire connector (crimp style) and now i dunno what guage the connector should be. The wire in question leads to the fuel pump.
any help?
Old Aug 15, 2002 | 09:13 PM
dustin's Avatar
Default Re: what guage wire to use? fuel pump. (Mazmay)
Don't use crimp connectors on wires to the fuel pump, trust me.
Solder them together
Old Aug 15, 2002 | 09:38 PM
raene's Avatar
Default Re: what guage wire to use? fuel pump. (dustin)
Isn't that a little dangerous, soldering wires with an open gas tank right there?
Old Aug 15, 2002 | 09:51 PM
spettinger's Avatar
Default Re: what guage wire to use? fuel pump. (raene)
put something over the open fuel tank, and solder it up. it would take a spark to ignite something. soldering guns don't produce sparks. what fuel pump are you using and why are you soldering?
Old Aug 16, 2002 | 11:21 AM
Mazmay's Avatar
Default Re: what guage wire to use? fuel pump. (wreckedhatch)
Okay maybe i should have been a bit more descriptive.
The wire in question is the yellow/black wire going into the fuel pump cover. I had spliced a switch in this wire as a fuel pump cut off switch. I have taken that switch out and want to securely connect the wire together again..that's why I want to know what guage connector to use. I dunno how to weld wires together, hence the connector.
I hope this is a bit more clear.
Thanks
Old Aug 16, 2002 | 12:34 PM
Urban Business
Guest
Posts: n/a
i hate the non oem style fuel pumps. they usually dont fit and you have to re connect everything w/o the clip (makes me nervouse). buy a walbro $113 shipped usually
Civic Si Kid
Audio / Security / Video
May 17, 2009 12:26 PM
blackeg
Mar 12, 2007 02:07 AM
nboost
Dec 1, 2006 09:39 AM
boosted k20
Aug 16, 2004 07:58 PM
