something is bent i need some advise
alright. my crx has a REAR toe out problem only one the passenger side and the toe adjuster is already all way adjusted(previous owner). something has to be bent eather my rear trailing arm or rear lower control arm. any suggestions
maybe someone had the same problem. i just dont know witch one to get first lol. just curious witch one would prob. bend first with enof force i dont know. just someone elses opinion.
Perhaps if you had a look it may be obvious where the metal has been stressed. If you need to, perhaps look at the other side to see where it may not look the same.
Taking photos of either side and comparing them may help too.
I had a bent front lower control arm, and I noticed that there is a casting seam that runs the length of the arm that should be straight. I pulled a string across it and I could see that it was bent. Check yours out. (Keep in mind it is also possible that it may have twisted a little too.)
lowgman
Suspension & Brakes
Sep 9, 2005 06:10 PM
