abs removal...don't want abs anymore...
Ok, the titlee says it all!
I own a 96 gsr and want to take out the ABS out of my car...Sensor and other things are alwredy bust so instead of fixing it I prefer to take this out... Oh! and before you ask and tell me advice, it's a track car and I'm shaving weight right now...
I'm just not totally sure exactly what I need to swap from an RS model.. Can somebody list all the part I will need to swap...? master? line? booster? splitter? I need to know...
As far as I know you'll need all of the lines that sit on the fire wall that go into the prop valve. You'll need 40/40 prop valve. I was told you'll also need a 15/16th master cyl unless you reflare the lines going into the stock master. If you use the non-abs master you'll need the non-abs booster as well.
Look on acuraoemparts.com for a diagram. It should list all the lines going into the prop valve you'll need.
http://www.acuraoemparts.com/delray/...All&vinsrch=no
Yes...There is two ways of doing it...the that has already been mentioned, and delete your whole abs system then swaping to a non abs 40/40 prop. might need to bend a lines a bit, but can keep your MC and BB.
