timing belt q
Old Apr 21, 2009 | 09:37 PM
ryanevansoh's Avatar
Default timing belt q
ok so i installed my cams and when i put the belt on i loosened the tensioner so i could slip the belt on the cams. is there a way i could tighten the tensioner back up without taking off the crank pulley?
Default Re: timing belt q
motor is b18a1 btw
Old Apr 22, 2009 | 12:12 AM
Redline130's Avatar
You don't need to do anything with the crank pulley to tighten the tensioner. Are you trying to set the tension on the timing belt?
Old Apr 22, 2009 | 01:47 PM
yes tming belt is a little loose
Old Apr 22, 2009 | 02:21 PM
mjfubar101's Avatar
Ya then you need to do as the manual says and turn the crank I believe take up the slack then tighten the tenioner
Old Apr 22, 2009 | 02:57 PM
sde780's Avatar
Turn it at least 3 teeth past TDC with tensioner slightly tightened, then tighten tensioner down
Old Apr 22, 2009 | 08:51 PM
ok thanks for the help guys
danteisme
Sep 21, 2009 06:12 AM
B18C5_VTEC
Nov 2, 2007 09:18 AM
RoB316
Apr 6, 2007 10:09 AM
omgwtfbbqcrx
Feb 16, 2006 09:38 PM
drew2
Apr 20, 2005 06:17 AM
