o2sensor,cap,rotor for 1gen b16a
Old Aug 15, 2002 | 08:37 PM
.ShawnD.'s Avatar
Default o2sensor,cap,rotor for 1gen b16a
are they all the same off a 99SI civ
cuz i remember someone saying the wirings different on a b16a then a b16a2 any help would rock!! thanks
Old Aug 15, 2002 | 09:42 PM
raene's Avatar
Default Re: o2sensor,cap,rotor for 1gen b16a (.:s h a w n D:.)
I'm pretty sure you can use the stock CRX parts for those. I think that's what I did, really can't remember now
Old Aug 15, 2002 | 09:45 PM
spettinger's Avatar
Default Re: o2sensor,cap,rotor for 1gen b16a (raene)
O2 sensor--single wire only!! unless you have a custom OBD1 or 2 setup. not completely sure on the cap and rotor, a 92-93 GSR would be an OBD 0 vtec cap, give them a shot. no need for a cap unless it's broken. my hesitation problem was solved with an O2 sensor and fuel filter.
Old Aug 16, 2002 | 12:10 AM
samiam's Avatar
USE 90-91 Integra O2 , cap, rotor, works.
Old Aug 16, 2002 | 05:47 AM
.ShawnD.'s Avatar
Default Re: o2sensor,cap,rotor for 1gen b16a (samiam)
thanks, what about model
90-91 GS>LS>GSR>RS??
Old Aug 16, 2002 | 06:27 AM
HybridFiend's Avatar
It is safe to just go with the LS trim level, in some cases a cheaper price too.
Old Aug 16, 2002 | 08:28 AM
Francois's Avatar
Default Re: o2sensor,cap,rotor for 1gen b16a (HybridFiend)
They were no such thing as a GSR in '90-91!
RS-LS-GS are all the same.
GSR 92-93 is OBD 1.
Crx cap doesn't fit because there is a little pin from the distributor and it is situated somewhere else on the B16 distributor.
But,the 90-91 Teg cap will fit,no problem.
Old Aug 16, 2002 | 10:45 AM
raene's Avatar
Default Re: o2sensor,cap,rotor for 1gen b16a (wreckedhatch)
This Part # does NOT work, just a warning (I know it's one of the Integra p/ns):
30102-PT2-026, here's why (B16A on the left, '92-'93 Integra cap on the right):
Old Aug 16, 2002 | 11:35 AM
FUP23's Avatar
New User
You need 90-91 Ditrib thats why it didnt work
Old Aug 16, 2002 | 03:58 PM
.ShawnD.'s Avatar
Default Re: o2sensor,cap,rotor for 1gen b16a (Devin17)
awesome .. thanks for all the helP!!
b16er
Jan 11, 2007 06:32 PM
EF86
10
Jun 26, 2006 09:32 PM
thatbluecrx
Dec 9, 2004 03:28 PM
8ball629
Mar 31, 2004 08:43 PM
90SIhybrid
May 17, 2002 08:21 PM
