help with all motor b16 setup
i have a b16a2 that i just started rebuilding i had it port and polished all new valves, dual valve springs, retainers. im looking to get stage 2 brian crower cams and some sort of cam gears.
any suggestions to anything about the build feel free to say something looking to get as close to 200 as possible...
also which ecu should i run..
should have gotten a 3 or 5 angle valve job while you were at it.
get some ITBs. honda tuning just had an article on the most popular brand twm, but claimed the new brand was better.
get the best header you can afford(hytech, comptech, toda)
everyone will probably argue so i wont say, but go as high on the compression as your engine builder will allow on pump gas, unless you will hassle with race gas.
just buy good parts,etc.
you will spend thousands and barely break 200 unless you 2.0 it.
then u will be disappointed and wish u had gone turbo.
break it in right and get a good tuner.
we have had just as much luck with crome pro as we have had with hondata, for alot less money.
p28,p72,p30, or something obd1 converted to vtec will all be the same tuned. it does not matter
jlantic
44
Mar 22, 2005 08:24 PM
