b20 into 98 civic wiring help
hey guys,my friend is trying to finish up his swap so i figured i'd ask you guys,for starters the engine is a ob2b b20 motor with an 98 civic(obd2a automatic) harness,my first question is what do i plug into the clutch pedal,all i see is a dangaling brown 2 plug with i thing blue and red wires,also i hear the starter turn on but it does not crank,any help would be greatly appriciated
if its automatic use ls harness automatic.......i have b20 automatic.... the only thing is my cluster dont work............... hopefully i could help a bit..... i had no problem wit wiring and turned on rite away..........
