Unable to tune the ignition timing to required mark on F20a (=F22a)
Old Apr 21, 2009 | 08:24 AM
eintsius's Avatar
Default Unable to tune the ignition timing to required mark on F20a (=F22a)
Hello,
I had the engine belt replaced and now cant reach the red timing mark that tunes the ignition. On this engine the timing marks are on the alternator pulley. The red mark which is in the middle of these 3 side-by-side marks reaches almost the fixed mark, but 2...3 mm before correct position reaches the distributor fully retarded position. In fully advanced position the marks move forward 4..5 cm toward the master cylinder. Could the camshaft be 1 teeth misaligned, or is it sth else?
Henrik
Old Apr 22, 2009 | 03:36 PM
motoxxxman's Avatar
Default Re: Unable to tune the ignition timing to required mark on F20a (=F22a)
i would say its a safe guess that the timing belt is off a tooth or two
Old Apr 23, 2009 | 06:27 AM
mattsnooz's Avatar
I would tend to agree. Need a bit more info though
How does it run? I would assume its not running very well so you attempted to see if ignition timing was not set properly by whomever did the belt?
Old Apr 23, 2009 | 04:59 PM
G2IntegraGS's Avatar
Are you sure you have the pickup on the correct wire?
Old Apr 23, 2009 | 07:35 PM
EG6KILIN's Avatar
How to check the ignition timing
Old Apr 23, 2009 | 09:31 PM
boostedmonkey's Avatar
I know there's an F20B, that came in the Euro Accords, but i've never heard of an F20A. What did that come in?
journeyquest
Aug 31, 2014 09:04 AM
Pancho2193
Mar 13, 2013 10:38 AM
DennisWaller
Jun 1, 2009 11:21 AM
dr_latino999
Dec 2, 2004 09:55 PM
