Tilton Twin Disk..... Throwout bearing....
Old Apr 21, 2009 | 07:09 AM
LS-VTEC-TURBO-EF9's Avatar
Icon3 Tilton Twin Disk..... Throwout bearing....
Hello all. I recently purchased a Tilton Twin disk for my drag race set-up.
But i'm not to sure what Throwout bearing i should run. Ive seen the ones tilton make, but they are pricey. I was wondering what my other options are?
Old Apr 21, 2009 | 08:23 AM
Default Re: Tilton Twin Disk..... Throwout bearing....
Help!!!
Old Apr 21, 2009 | 08:35 AM
jdm inc's Avatar
you can use a stock one just have to modify it a little..
Old Apr 21, 2009 | 08:37 AM
Originally Posted by jdm inc
you can use a stock on just have to modify it a little..
Do you have details??
Old Apr 21, 2009 | 08:44 AM
jdm inc's Avatar
i used a dremel to cut out the middle part of the bearing so it doesnt hit the preasure plate and that the actuall bearing is riding on the pressure plate. hope that helps.
Old Apr 21, 2009 | 09:49 AM
Hmmmm...... Pics?? lol
Old Apr 21, 2009 | 10:06 AM
Anyone else have details??
Old Apr 21, 2009 | 10:11 AM
jdm inc's Avatar
sorry didnt take no pics of the bearing..... if you give will at exospeed a call he is the one who explained it to me i purchased my tilton twin disk through him. www.exospeed.com
Old Apr 21, 2009 | 10:12 AM
YZFR6's Avatar
I would definitely invest the money to get the Tilton Hyd. throw out bearing and flow control valve. If you want to modify the Honda bearing, I would recommend bringing it to a machine shop and have them put it on the lathe. The inner part of the bearing should be shaved down before the contact face of the bearing.
Old Apr 22, 2009 | 09:04 AM
rip94delsol's Avatar
The tilton throwout bearing is one nice looking piece. Some have had great experience and others not. Alot of the Outlaw guys run this setup with a control valve which is the wise thing to do.
The ppl who have had problems do not properly install the unit. YOU HAVE TO RUN A PEDAL STOP.(thats what it says in the instructions)
I have mine but its not completly setup yet.(also cleans up the engine bay quite a bit and theres more clearence.
Old Apr 22, 2009 | 10:45 AM
Will_H's Avatar
IMO you spent all the money on a $1400+ clutch why not spend the extra and do it the right way with the Tilton thowout bearing setup
Old Apr 27, 2009 | 07:33 AM
ExospeedAMcrx's Avatar
If you bought a Tilton kit, there should be a page in the instructions on how to modify an OEM throwout bearing.
Old Apr 27, 2009 | 04:08 PM
AROD's Avatar
more info on this. i have a CC twin plate. would like to know if any has tried the tilton Hyrdro throwout bearing on this clutch.
Old Apr 28, 2009 | 05:22 AM
ALL IMPORT's Avatar
wondering the same would it work with a exedy twin as well?
dont see why it wouldn't unless it wont line up with the pressure plate correctly
teddy_dc2
Nov 3, 2010 04:56 PM
heavy duty
Mar 12, 2010 01:16 PM
hammergunner
Sep 11, 2008 08:07 PM
utahbmx
Mar 21, 2006 12:49 PM
ArinX
Feb 26, 2003 12:01 AM
