Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
massive vibration
Old Apr 20, 2009 | 11:14 PM
Nighthawk R18's Avatar
Default massive vibration
so out of no where today my car started vibrating....no SHAKING. at about 1k - 1500 rpm after a tiny rev my "jdm" air freshener rattles and my b pillar bar is wavy when i look at it from my broadway rewview mirror. i havnt the slighted idea what the problem is. getting up to speed doesnt seem to have a problem because its all minimal vibration from my exhaust. but when i clutch in and slow down it vibrates again at the RPM range.
does anyone have any idea what could be wrong?!?!
Old Apr 20, 2009 | 11:16 PM
shietzitzkien's Avatar
Default Re: massive vibration
motor mount?
Old Apr 20, 2009 | 11:29 PM
could be. but from my naked eye and a flashlight they seem fine. tranny mount too.
also. there isnt a CEL and the engine does not vibrate more then the rest of the car.
**** it could be a mount. or someshit
Old Apr 21, 2009 | 12:11 AM
MiX's Avatar
MiX
aftermarket exhaust, if so your exhaust might be hitting the bottom of the car and vibrating, caused my rubber mount coming off the exhaust or something.
Old Apr 21, 2009 | 02:42 AM
EricRyan's Avatar
Testing FWD motor mounts (manual trans.):
1.) Grab assistant (to watch your engine bay)
2.) Get in vehicle, start engine, pull e-brake as tight as humanly possible
3.) Put vehicle in 1st or reverse
4.) Rev motor up to 2,000rpm
5.) "Dump" the clutch, quickly pushing clutch back to floor as soon as it engages, repeat
6.) Have assistant describe the amount of motor/trans flex
There should be little to no flex.
Testing FWD motor mounts (automatic trans.):
3.) Put vehicle in D or reverse
4.) Push brake pedal in very hard
5.) With brake pushed in, torque the motor up with the small, quick blips of the gas pedal
Old Apr 21, 2009 | 11:17 AM
Zeusone's Avatar
stock car?
Old Apr 21, 2009 | 01:06 PM
going to try that test for mounts.
my exhaust is on there fine i got underthere and shock it side to side and it doesnt touch any part of my car.
my car has intake exhaust
Old Apr 21, 2009 | 06:19 PM
miketat594's Avatar
if it happens when clutching , it could be your balance shaft....YIKES!!!GL
Old Apr 21, 2009 | 07:36 PM
chiggin's Avatar
I found this video of someone doing the motor mount test. I know it is a VW in the video, but it gives you an idea of what it should look like if there is a bad motor mount.
http://www.youtube.com/watch?v=uKnQQoORbtk
Hope your car is ok man!
GSR4door
Feb 19, 2018 04:06 AM
mattcalica
Jan 19, 2005 04:43 AM
TurboTagTeam
11
Dec 24, 2004 12:00 PM
Rocks
11
Jul 23, 2004 11:19 AM
