changing out clutch
Im changing out my clutch on my 06 RSX Type S and im a little confused, i found a link that shows me what to do but was wondering if i really have to take down the subframe from my car to change out the clutch or is their an easier way and also in the link in step 25 when taking down the subframe whats holding the engine from faling, did this guy use an engine hoist or something to hold it up or does it hold by itself. this is the link (http://customdc5.my-php.net/diy/clutch/) any input will be greatly appreciated, thanks
but the subframe has to come down with the engine staying up and rolling out the subframe with something under the car holding up the engine, well cant really see it happenin (in my head), im hella confused.
Your upper mounts will support the block, I still used a jack under that though, and another under the tranny to maneuver it out after the bolts are all released, shifting cables removed, reverse switch, and tranny mount if there is one.
cool, maybe this way i wont be all confused thanks, im gonna try to start mine this week coming up just need to get my check to buy the Tranny fluid and grease for the bearings.
Yes, you have to take off the subframe. use a floor jack to keep the motor in place. make sure the way the motor is sitting is even on all sides or you will crack / break a mount (i did, lol). its really easier done then said IMO. the most complicated part of this operation is the subframe. have fun puttin the subframe back on, too! haha
we knocked it out in two and a half hours its easy its like any other civic clutch except you have 4 subframe bolts
and mitcho can vouch on our time
Ill be sure to bring a couple of friends with me or atleast my brother thanks for the info and advise ima start on it as soon as my flywheel comes in and i try to put pictures of the job if i remember, thanks
ducsaim
Oct 23, 2010 05:41 AM
Mattgrimes
Honda Civic (2006 - 2015)
53
Aug 30, 2009 04:00 AM
labatt50
Jul 5, 2006 09:25 PM
