Engine Hiccups at idle but rpm is stable
Old Apr 20, 2009 | 06:47 PM
JJexpress's Avatar
Default Engine Hiccups at idle but rpm is stable
Hi,
My engine hiccups pretty frequently at idle - It's very quick cut off sound which you can here from the exhaust and the car shakes very slightly (rpm does not change or bounce) - Could it be air bubbles in my coolant system?
Old Apr 20, 2009 | 08:54 PM
nemesiskrp's Avatar
Default Re: Engine Hiccups at idle but rpm is stable
I want to know this to, mine hiccups to I just did not know what to call it. it could be coolant air bubbles.... anyone know?
Old Apr 21, 2009 | 09:10 AM
JJexpress's Avatar
Bad fuel pump?
Old Apr 21, 2009 | 05:14 PM
nemesiskrp's Avatar
hope not
Old Apr 21, 2009 | 05:27 PM
JDMLude850's Avatar
funny, mine started doing this also awhile back
Old May 6, 2009 | 11:07 AM
JJexpress's Avatar
anyone?
Old May 6, 2009 | 06:27 PM
Remiss's Avatar
mine does this...was way worst before i changed the plugs so maybe check the plugs...
I wouldn't go as far as the fuel pump as then the car would pretty much die and u would notice a drop or bounce (most likely) in the idle from the motor starving for fuel
one thing to consider would be the IACV...most ppl neglect to clean it
that and the EGR witch is engaged at idle. if i recall corectly the egr operates until 1800 rpm (in my f22b anyways) but pls correct me if I am wrong
Old May 18, 2009 | 09:10 AM
JJexpress's Avatar
I just replaced my spark plugs and it still hiccups. Since I have been driving it for awhile it is now even worse. The exhuast cuts and the whole car vibrates. Not only in idle but while driving! Please Help!
Old May 18, 2009 | 06:39 PM
Remiss's Avatar
that bad haha... throwing any codes??
Old May 18, 2009 | 06:43 PM
98vtec's Avatar
moderator emeritus
turn the car on with one plug out of the head and grounded to the valve cover and see if there are any ignition sparks that are weaker compared to the others.
Old May 18, 2009 | 07:02 PM
Remiss's Avatar
u sir are a genius...
Old Sep 22, 2011 | 10:11 AM
cptbarkey's Avatar
any resolution to this? i am experiencing the same exact problem with a 98 accord 4 cylinder.
Old Sep 22, 2011 | 05:18 PM
cptbarkey's Avatar
to answer my own question, it was crappy bosch spark plug wires, and/or possibly bad NKG spark plugs. new NKG plugs and wires fixed it.
Hyde1
24
Apr 8, 2013 09:59 AM
Paddy_Irishman
Jun 28, 2006 06:49 AM
AMS_92EX
Mar 28, 2006 11:55 AM
Mik3
Feb 5, 2006 06:55 PM
Outkast95LS
Dec 27, 2004 05:36 AM
