ECU Woes...
Old Apr 20, 2009 | 05:20 PM
AMG's Avatar
AMG
Default ECU Woes...
In short:
EM1
b16 block/b18 head w/
[I, H, E, IM, Fuel Rail, Cams, Cam gears, etc.]
I have two ECU's right now that are both useless.
1.) Crome chipped was purchased when original motor was in car and had issues. Sent back to Rywire who sent another and still issues (no start after fuel, revving to 5k, etc)
2.) Hondata s100 purchased when new motor was installed. ECU was purchased and tuned from Shawn at Church motors and shipped to Florida. Motor will surge (gain/lose power dramatically) up the power band and at 7k, the car dips violently downward and the car loses all power.
I was going to go get a tune from a shop that says they tune Hondata, but when I called they state that they only tune s300 and don't have the software for s100 chips!?! So, I am going to look for a new shop (hard to find), but just wondering if this was a fuel cut off and a freaked up map that was burned to the ecu or what.
Sorry if this is a bit scattered, just annoyed.
Old Apr 20, 2009 | 06:26 PM
mar778c's Avatar
Community Builder
Community Influencer
Default Re: ECU Woes...
Where are you located? There are a number of good shops that tune in FL.
The second ecu sounds like it may just need a good base map to start from. Contact Mtber or 98vtec, I believe they are in Florida and may be able to help you remotely. If not I knew innovative motorworks(more locale to me) or CFT can help.
Old Apr 20, 2009 | 07:58 PM
AMG's Avatar
AMG
Thanks man. I'm in Jacksonville. Going to call a shop called Stage 6 tomorrow. Hopefully they can tune it, never thought it would be this difficult with Honda's most popular tuning software.
Old Apr 20, 2009 | 08:56 PM
msb1510's Avatar
Good luck getting them to answer the phone. Sometimes its better to just stop by.
Old Apr 21, 2009 | 05:55 AM
98vtec's Avatar
moderator emeritus
From what i have heard, Mase doesnt even take in low powered cars anymore. I could be wrong.
If you get an s300 or want to pay for an ectune license, let me know. I'm in tallahassee.
Old Apr 21, 2009 | 07:57 AM
AMG's Avatar
AMG
Called several times and left a message, doubtful on getting it tuned at Stage 6. So, I only have a Hondata s100 and need tuning locally, any other options? This sucks.
Old Apr 21, 2009 | 10:09 AM
b19coupe's Avatar
Hello AMG; this is Todd from Church Automotive Testing.
I am sorry to hear that you are having problems. There are a couple of things that I need to point out. When we send out a chip with an ECU, it is only loaded with a basemap. A basemap is designed to get the car up and running and allow you to drive the vehicle safely to a dyno to get tuned. Nothing more. It is a map from a car with mods similar to yours.The basemap is not designed to make loads of power or to be run full throttle on the street. We do several things to the basemap that will have the opposite effect. We add fuel and pull timing from the tune to make the car safer to drive and prevent engine damage. We will also put in a lower rev limit, 7,000 RPM on a B-series, for instance. This allows the customer to get the car to the dyno and have the engine tuned to it's full potential.
Hondata has a list of dealers on their website here:
http://www.hondata.com/dealers.html
You can also contact Hondata directly to get a tuner recommendation from them. If you are unable to find a tuner in your area, you can also take the car to a dyno and get a printout of your A/F at full throttle, as well as HP/Torque. We would be happy to make changes to your map based on those graphs that would be more tailored to your specific application. Contact us and please let us know how we can be of assistance. Thank you.
Todd-Church Automotive Testing.
Old Apr 21, 2009 | 10:40 AM
Rocket's Avatar
I would check fuel pressure, fuel pressure regulator, fuel pump etc before solely focusing on the ECU.
The ECU controls the inputs of fuel and spark to da motor; the old saying "garbage in, garbage out" will hold frustratingly true.
Old Apr 21, 2009 | 11:48 AM
msb1510's Avatar
Hey AMG, I'M in Jax as well. Have you tryed calling Speed Fab in OP, Tachton ,or maybe Velocity Trends, but Velocity is a bit on the pricey side.
Speed Fabs # 298-0005
Tachyon # 367-0390
Velocity # 997-9903
I hope this info can help you out, Good Luck.
Old Apr 21, 2009 | 07:57 PM
AMG's Avatar
AMG
Thanks Todd. I originally purchased the ecu through a local H-T seller (wunfstgsr) who I also bought the motor off of. He spoke with Shawn and told me to get a list of all the parts I would have on the car and he was going to get Shawn to burn a map off of these specifically. So not sure what went wrong, but I spoke with Shawn and he was just as shocked as I was.
No pun intended as you guys have been great and sh*t happens. lol Just wouldn't think it would be this hard to find a shop to tune the damn thing! Wish you guys were local!!
Old Apr 21, 2009 | 07:59 PM
AMG's Avatar
AMG
Thanks, all checks out.
Tachyon # 367-0390
Velocity # 997-9903
Checked with Velocity and they said they can only tune s300 chips WTF. As far as the other two, I have never heard of them, but will give them a call. I just don't want a **** tune, ya know?
Old Apr 22, 2009 | 06:36 AM
00MRSi's Avatar
There's gotta be someone in FL that can tune your car. Titan Motorsports still around?
Old Apr 22, 2009 | 08:08 AM
Godspeed07's Avatar
Titan is still here but they are in Orlando....there's also CFT (central Florida turbo)...both reputable shops, both in Orlando......not sure if that works for you or not.
Ninja Edit: Maybe contact DonF....hes located in Jax, he may have some recommendations.
Old Apr 22, 2009 | 05:22 PM
msb1510's Avatar
Wow, if Velocity couldn't do it, you really should try Speed Fab, they've been around longer than Stage 6. If all else fails, GET A TOYOTA! No really, keep trying Stage 6. Their customer service is bad, as far as answering the phone gos, but they really do know their **** when it comes to tuning. Once again, Good Luck.
Like I said, some times, with Stage 6, it is best to just stop buy their shop. I do not know their address but here are some basic directions. They are about 1/4 mile north of University Blvd. on Phillips Hwy. They are on the rite. Look for a Wheel Shop, go behind it, their all the way in the back.
Old Apr 22, 2009 | 05:41 PM
98vtec's Avatar
moderator emeritus
Call don.
Old Apr 22, 2009 | 06:21 PM
projectTeG's Avatar
yes call don, he can prolly direct you in the right direction. also i know of a local tuner that does pretty good work, for a fair price. lemme know man.
Old Apr 23, 2009 | 05:33 AM
AMG's Avatar
AMG
Thanks for the help guys. I'll PM DonF and see what he says.
Old Apr 23, 2009 | 06:09 AM
00MRSi's Avatar
Ninja Edit: Maybe contact DonF....hes located in Jax, he may have some recommendations.[/QUOTE]
Oh crap, yeah DonF should be able to help! lol
Old Apr 23, 2009 | 08:33 AM
AMG's Avatar
AMG
Originally Posted by DonF
Sorry, i cannot do the S100 either.
I'm at a loss right now...
Old Apr 23, 2009 | 09:47 AM
Relic1's Avatar
IMO it would be worth the drive... http://www.phearable.net/tuningsolutions.html (tampa ~3 hours)
But he lists S100 as an option, and you can always use the Crome ECU and have him install eCtune instead. (as simple as burning the chip again)
Again IMO, eCtune would be way better than the S100 or Crome setup.
Old Apr 23, 2009 | 08:20 PM
AMG's Avatar
AMG
eCtune? I thought Hondata was always the way to go. *shrug* Shows how much a few years can leave you clueless about aftermarket performance.
Old Apr 24, 2009 | 08:11 AM
AMG's Avatar
AMG
So, I just spoke with Mase who is a SUPER nice guy by the way. He said he hadn't tuned s100 software in a long time, but would order a burner and tune the car! He said he should have it by Wednesday, so I can't wait!
BTW, my buddy finally did a valve adjustment due to a more than normal ticking noise and found the valves to be very loose. Although the car sounds 10000 times better and runs much better, both ecu's decided to fully crap out now:
The crome will run the car, but the idle fluctuates erratically and stalls 8/10 times at a stop. It threw a cell one of the times we had it in there for the IACV.
Then we put the s100 back in and the car dumps so much fuel that the gas gauge drops significantly when giving gas and stalls when trying to accelerate. This ecu is not drivable at the moment.
My only question is "How the F do both give out now that the car is adjusted properly?"
Old Apr 29, 2009 | 08:48 AM
AMG's Avatar
AMG
Bumping this up because I haven't been able to get back in touch with Mase. I've called several times and left messages, but got no response. Hopefully he calls me back within the next day or so, but if not, I'm stuck with a car that barely runs and 350$ waiting for someone who will tune my car. :-(
Any suggestions?
Old Apr 29, 2009 | 08:59 AM
98vtec's Avatar
moderator emeritus
ditch the s100 and spend 100 dollars or less for the ectune license.
Old Apr 29, 2009 | 01:04 PM
AMG's Avatar
AMG
I might just have to do that. Thanks.
