i messed up, help.
Old Apr 20, 2009 | 03:43 PM
Peeonu25's Avatar
Default i messed up, help.
im in the process of rebuilding my h22a, i took the head off today. figured id clean those pieces of aluminum that hold the cams in place. i was washing them in a tub with water, an all purpose cleaner mixed with amonia, i let them soak for 10 minutes came back and everything is now oxidized.
shorting of pulling out some 1200 grit sandpaper, how do i fix this?
Old Apr 20, 2009 | 05:51 PM
srmofo's Avatar
Default Re: i messed up, help.
pics???? do not sand the caps on the mating surface to the head or where the cam rides at.
Old Apr 21, 2009 | 09:56 AM
mouab18c1's Avatar
use brake cleaner...its what you should of used in the first place
Old Apr 21, 2009 | 10:11 AM
Peeonu25's Avatar
ill try it soon, thanks a lot. you should read my other post, the reason why i pulled the motor in the first place.
TheCrimsonGhost666
Aug 4, 2010 11:22 PM
Mushvroom
May 1, 2005 11:23 AM
4genaccordfreak
Jun 2, 2004 01:48 PM
Surubasi00
Apr 6, 2004 05:33 AM
navin
Dec 12, 2003 05:34 AM
