how long will this take?
Old Aug 15, 2002 | 06:25 PM
ijjz's Avatar
Default how long will this take?
dpfi -> mpfi on my 89 civic dx with 2 people and one of them is a better then average car mechanic, very good with wiring?
Old Aug 15, 2002 | 06:38 PM
FredoTheChimp's Avatar
Default Re: how long will this take? (ijjz)
shouldn't be a impossible task oh pm tortex he seems to be the Low Budget pro
[Modified by Accord92sir, 3:51 AM 8/16/2002]
Old Aug 15, 2002 | 08:23 PM
USDM 4G VTEC's Avatar
ill say first timer doing DPFI to MPFI it will take u abour 1-2 hrs.....
with experience.. like me .u can do that **** in about 35 min......
(wiring only, and well done, no shitty jobs!)
add another .5-1 hr to change manifolds......
Old Aug 15, 2002 | 09:27 PM
Louie B.'s Avatar
i set aside a weekend to do mine, my car was down for a week (wrong parts, broken parts, had to pull and replace manifold 3 times because of vaccum leaks, etc)
but I'm probably the worst case senario
Wiring was no problem at all. I re-pinned everything with an si harness in such a way that there are NO splices under the hood. I even used my old dpfi dizzy plug by the firewall for the 4 wires that needed to be added from the ecu.
[Modified by thumpu77, 8:58 AM 8/18/2002]
Old Aug 16, 2002 | 10:48 AM
tpr's Avatar
tpr
I did mine in about an hour. Use a soldering iron for all wire splices and be sure to make a connection in the engine bay so that if and when you need to remoeve the engine it will be a simple unplug as opposed to cut then splice when you go back in. A trip to your local junk yard to get the ecu plugs is well worth the time and effort. While you are there get the resistor box, drivers side fender weel near the firewall along with the injector harness to the intake. If you have the helms manual or a copy of both the dx and SI engine wiring it will help alot. Hybrid Honda has an article detailing exactly what to do.
http://tech.hybridgarage.com/tech/4g...-zc-wiring.htm
TPR
[Modified by tpr, 8:10 PM 8/16/2002]
Old Aug 16, 2002 | 10:54 AM
Urban Business
Guest
Posts: n/a
Default Re: how long will this take? (Accord92sir)
what you trying to say
mine took 12 hrs total, didnt have a dizzy, fpr or a proper evac hence the 12 hrs. wiring is about 15 min. oh i had a hacked up dizzy harness so i had to re do that... trying to get an obd1 dizzy to work sucks. that was a waste of 5 hrs prolly
if you have all the parts plan on 2 hrs mabey
[Modified by TorteX, 1:57 PM 8/16/2002]
Old Aug 16, 2002 | 12:02 PM
xci_ed6's Avatar
Default Re: how long will this take? (TorteX)
Can I use the DPFI fuel lines, my manifold came w/ hacked lines.
-Dustin
Old Aug 16, 2002 | 12:14 PM
Urban Business
Guest
Posts: n/a
Default Re: how long will this take? (Autocratic_1st_Gen)
hmm im not sure. see if their long enough, they should be
Old Aug 16, 2002 | 12:34 PM
ijjz's Avatar
Sweet, thanks for all the info guys! Seems like ill just start on a friday just incase something goes wrong, and be definitly done by sunday.
Old Aug 16, 2002 | 01:58 PM
nothing your cool i wish i could save money like you
blue91EF
Mar 3, 2011 08:46 PM
metal craft
Mar 18, 2007 07:34 PM
crxtreme27
Jul 2, 2002 05:54 PM
maximedx
Jan 13, 2002 07:24 PM
