zc timming
Old Apr 20, 2009 | 11:34 AM
sean burke's Avatar
Default zc timming
Is valve timing on a dohc ZC motor set by lining up the cam gear marks exactly with the upper surface of the head and the single mark on the crank pulley at #1 TDC? Are there any special tricks to setting this?
Old Apr 20, 2009 | 11:44 AM
jlicrx's Avatar
Default Re: zc timming
the marks that are next to each other on the gears should line up with the top of the head - the marks on the opposite sides of the gears will be one tooth above the top of the head - the single mark off to the right of the 3 ignition timing marks on the crank pulley is the TDC mark ('B' in picture) and needs to align with the pointer on the timing belt cover
Old Apr 20, 2009 | 04:23 PM
sean burke's Avatar
thank you, this clarifies some of the vagueness of the Rover 416 Haynes manual
h23vtec_dc2
Mar 7, 2010 12:20 PM
Yuleluder
Apr 14, 2006 08:04 PM
fastbrakes
May 31, 2004 07:06 PM
slooogsr
10
Sep 28, 2003 07:13 PM
zccrx
12
Apr 23, 2003 07:14 AM
