92-95 Cluster B series Ac Bracket Accord And Civic O2 Sensors Map Tps Chipped Ecus
Old Apr 20, 2009 | 11:01 AM
JDM-JAMES's Avatar
Default 92-95 Cluster B series Ac Bracket Accord And Civic O2 Sensors Map Tps Chipped Ecus
Bunch of stuff Shipping not included pm me for prices
y7 Throttle body 10 bucks with iacv and tps sensor
92-95 civic 94-01 integra rear t bracket mount that bolts to the subframe fits manual and auto 10
92-95 civic cluster with tach Its a manual i sold the auto in the pic the manual is off a civic vx 75
92-95 civic Dash board light dimmer switch 10
2 tps sensors fits all civic and integra throttlebodys 10 each
4 map sensors 3 are throttlebody mounted and the other is firewall 10 each
Fic 550cc Injectors For honda and acura Peak and Hold require resistor box work great 150
10 civic and accord o2 sensors some for accord and most for civic let me know what you need 25 each 30 for almost new bosh o2 for accord
Del sol p30 ac bracket perfect for b swapped civics running ac 80 these are rare
LOCATED NEAR MISSION VALLEY 92116 AREA ADAMS.AVE
619-813-5149 JAMES
I ALSO DO ECU CHIPPING OBD1 ECUS ONLY 92-95 CIVIC AND INTEGRA ECUS VTEC CONVERSIONS , SOCKETING TURBO OR ALL MOTOR BASEMAPS 180-800CC INJECTORS UPGRADED MAP SENSORS LS-V B20-V
REV LIMIT VTEC ENGAGEMENT SHIFT LIGHT ,DISABLE O2 I ALSO HAVE MANY CHIPPED ECUS READY FOR ANY MOTOR SETUP P28 CLONES 120 EACH I CAN HAVE PROGRAMED AND READY IN 2 HOURS LET ME KNOW WHAT YOU NEED DONE
Old Apr 20, 2009 | 01:55 PM
JDM-JAMES's Avatar
Default Re: 92-95 Cluster B series Ac Bracket Accord And Civic O2 Sensors Map Tps Chipped Ecu
bumppp
Old Apr 20, 2009 | 05:15 PM
JDM-JAMES's Avatar
bumpp
Old Apr 20, 2009 | 06:03 PM
dllscwbys94's Avatar
Hey will you ship the cluster
Old Apr 20, 2009 | 06:24 PM
wordsofvenom's Avatar
the p30 del sol bracket is for a vtec del right?
80 shipped to 90277?
Old Apr 20, 2009 | 10:41 PM
JDM-JAMES's Avatar
pmed
Old Apr 20, 2009 | 10:42 PM
JDM-JAMES's Avatar
i had it on my b swapped civic the torque mount lined up perfect with the frame rail bolts but didn't have ac hooked up and yes i can do 80 shipped
Old Apr 21, 2009 | 09:55 AM
JDM-JAMES's Avatar
bumpp
Old Apr 21, 2009 | 09:42 PM
JDM-JAMES's Avatar
bumpp
frisbie21789
May 9, 2016 03:16 PM
LS94tegra
Jul 31, 2009 01:18 PM
JDM-JAMES
May 2, 2009 08:29 PM
Jason kiDD
Sep 4, 2003 11:21 AM
