Precisionv 1600cc Voltage vs. Dead time compensation
Old Apr 20, 2009 | 08:27 AM
V-SPEC 1's Avatar
Default Precisionv 1600cc Voltage vs. Dead time compensation
Moved it here and hoping to see some of you might know what i'm looking for: Does anyone know what is the voltage vs. dead time compensation for these injectors? 1600cc part # 042-1600. I'm using S300. I know most of you big HP guys use these injectors and I'm assuming you guys might know what is the voltage vs. dead time compensation would be. thank you in advance.
Old Apr 20, 2009 | 08:31 AM
tony1's Avatar
Default Re: Precisionv 1600cc Voltage vs. Dead time compensation
You need to know the fuel pressure you're running and it will be significantly different using a resistor box vs. an injector driver, so you will need to specify that. Unfortunately, I don't have the info for you either way, but that is relevant information. We can test your injectors in the configuration they will be run if you want the correct info.
Old Apr 20, 2009 | 08:51 AM
V-SPEC 1's Avatar
Base fuel pressure is going to be about 45 psi using Aeromotive eliminator. I'm using FJO injector driver. Tony pm me how much would it cost me to do that thank you buddy.
Vic
1911Goodness
Dec 19, 2011 07:30 PM
Rosko
Dec 12, 2006 11:29 AM
94_CRVtec
May 25, 2005 06:49 AM
Nikoli
Apr 6, 2005 01:33 PM
