another battery relocate problem
Old Apr 20, 2009 | 12:38 AM
skipbudlong's Avatar
Default another battery relocate problem
got an ef hatch. try to put the battery behind the passenger seat. got the wiring done and when i went to put the terminals on, the ground wire from the valve cover to the frame got fried. then i tried it again and some smoke came out from the dash. and why would the oil light and beeping sound come on if the keys werent in??? Some help duuuuudes.
Old Apr 20, 2009 | 01:52 AM
blazed_racer's Avatar
Default Re: another battery relocate problem
did you do a wire tuck????
why would the crappy little VC ground fry???
bin the VC earth, does not do anyting, and wont do anything. just make up two new big thick gauge earth straps, for gearbox and motor/block.
if you did not do a wire tuck, relocating the battery to the rear is not hard to do, very fool proof; should not have smoke or fried wires....!!
Old Apr 20, 2009 | 12:43 PM
it did. Everytime i went to connect the terminal i would get a spark from the terminal as well. what does this mean blade????
Old Apr 20, 2009 | 01:03 PM
sleepingciv's Avatar
sounds like your hooking the pos to the neg termanals
Old Apr 20, 2009 | 05:15 PM
bprsk8r4272's Avatar
^ thats what im thinking also
Old Apr 20, 2009 | 07:50 PM
93formula's Avatar
^^^ another vote for the above, you may have fried more then just your valve cover ground...
Old Apr 20, 2009 | 10:58 PM
i thought i did fry something else, but everything seems ok. Why would the dash lights come on when i was connecting the terminals? The key wasn't in.
Old Apr 21, 2009 | 08:00 AM
Zeppelin's Avatar
So tell us where you connected the Red lead in the engine bay and where did you connect the Black lead? Hopefully you are using a local ground near the battery for the black lead.
Old Apr 21, 2009 | 12:03 PM
alright. I bought a 70 something inch long battery cable to connect it from the starter to the battery. Then i bought a 12 or 14 gauge cable to hook up the fuse box in the engine bay to the battery. Ran both through the firewall and hooked up the terminal to the battery then i hooked up the ground under the center console on one of the two screws infront of the shifter. When i went to connect the ground i got sparks. Then i tried hooking up the positive first and i got sparks and smoke and dash lights.
Old Apr 21, 2009 | 01:39 PM
shane21085's Avatar
did you run a rubber "O" ring through the fire wall or just drill a convent hole and push the wires through with little or no regard for the sheath that covers them? if you did then you have probably stripped some the the covering off the wires and now your "+" battery cables that are going through your firewall are now grounded to the firewall "since it is metal and a part of the chassy" and your shorting out something causing sparks to fly all over your car...
However if your not pre-said rocket scientist and you did place some sort of a non conductive barrier in the firewall then your problem may be as simple as you ran a ground to a positive by mistake go back and check all of your wires and make sure that the grounds are grounded and the positives are ran to positive terminals.
Old Apr 21, 2009 | 01:57 PM
I passed the cables through an already existing "o" ring. the cables did not get stripped.
Old Apr 21, 2009 | 02:51 PM
shane21085's Avatar
ok but have you check all you wiring yet. i can almost guarantee that you've crossed something somewhere. i did a relocation on my CRX the other day and i had very little problems other then cramped space with a b16 in the engine bay. its pretty straight forward process dude if sparks fly then somethings crossed.
Old Apr 21, 2009 | 02:54 PM
i put mine in the hatch and had no problems
Old Apr 22, 2009 | 01:16 AM
alright. Im gonna give it another try. Ill let you guys know whats up. Ill try and take some pictures too.
Spawne32
Jun 28, 2011 10:41 AM
90Rexx
Nov 27, 2010 07:38 AM
HONDAlover369
Sep 26, 2008 07:56 AM
msinsky14
May 23, 2007 06:44 PM
96b18c
Jun 3, 2004 07:29 PM
