whats a good brake set up for my dc2?
i have an 01 gsr, the previous owner put a tenzo r big brake kit on it(front n rear) but i want to get rid of it because i want to put smaller rims on my car(fifteens). I am thinking of maybe just putting on some OEM gsr rotors n calipers and getting some good pads. what would be a good setup that has good stopping power and also isnt too expensive? or should i just go with OEM?.....and the gsr is my daily driver/project car
is that one of those corny kits that uses the OEM caliper? you could just go back to stock i suppose if you don't need more for your driving habits. another option are the 23T calipers and redrilled prelude vtec rotors. they will just barely clear a 15"
If you dont want hassle of grinding down things and just want OEM bolt on, I say stick with stock dc2 calipers and get some GOOD i pads and that be more than enough for your car.
Remanufactured Front Calipers $60 x2= $120
Remanufactered Rear Calipers $110x2= $220
Hawk HPS Street Brake Pads:
Front Axle: $64
Rear Axle $51
Since your already that far I would switch to stainless braided lines.
Goodridge G-Stop Brakeline Kit $110
Don't forget you will need a bottle of Dot 3 brake fluid to bleed the system. $10
Total: $580
Sources for prices-
Calipers:
http://www.prostreetonline.com/
Brake Pads & Lines:
http://www.tirerack.com/
Front Axle: $64
Rear Axle $51
Total: $580
Sources for prices-
Calipers:
Brake Pads & Lines:
and if i did use the prelude rotors would it matter what year?
Noah Santana
Nov 30, 2016 04:57 PM
scorp965
Mar 24, 2010 11:05 PM
