2 turbos and kit for sale
Old Apr 19, 2009 | 08:46 PM
jrp355's Avatar
Default 2 turbos and kit for sale
- first turbo is a jdm sport turbo
Specs
Features
Stage 3 turbo capable of 350-450 HP
Capable of 25-35 PSI output at peak power performance
Wet float bearing
External wastegate with provisions for internal actuator
Compressor
Inlet (ID / OD) = 2.5" / 3"
Intake (ID / OD) = 1.75" / 2"
Inducer = 52.8 mm
Exducer = 75.5 mm
Trim = 49
A/R = 0.50
Turbine
Outlet = 2.25"
Turbo flange = T3
Downpipe flange = 5-bolt T3
Inducer = 57.8 mm
Exducer = 73.4 mm
Trim = 62
A/R = 0.63
Center Section
Oil cool system
Oil feed = T3
Oil return = T3
- manifold is a blox b series manifold
- second turbo is a Garrett GT2560R GT28R Turbo BB T3 4 bolt AR.48 Polished turbo
specs
Turbine
-Wheel: 53mm w/ 62 trim
-Housing: .64 ar
Compressor
-Wheel: 60mm w/ 60 trim
-Housing: .60 ar
- wastegate
38 mm adjustable wastegate
also comes with 3 inch wastegate and exaust dump.
will sell everything for 600 obo
Old Apr 19, 2009 | 08:47 PM
jrp355's Avatar
Default Re: 2 turbos and kit for sale
bump
Old Apr 20, 2009 | 09:12 PM
jrp355's Avatar
bump
SlidawayzSteve
Jan 20, 2011 07:39 PM
gecko49
Jan 8, 2009 10:23 AM
project civic
Apr 27, 2005 01:51 PM
poid
May 5, 2003 09:02 PM
