ls/vtec build
Old Apr 19, 2009 | 01:49 PM
mustwonder7's Avatar
New User
Default ls/vtec build
getting ready to start and ls/vtec build just looking for some input on the setup im looking to run.
gsr head
crower stage 2 cams
Old Apr 19, 2009 | 01:52 PM
New User
Default Re: ls/vtec build
crower stage 2 cams
crower dual spring
crower stock diameter valves
crower retainer
b18a1 bottom end
not to sure on
what would be a good piston to run no spray will be used
going to go with an itr manifold with a 70mm throttle body
and rmf header
Old Apr 19, 2009 | 01:55 PM
fiero87's Avatar
get some OS p30's from honda and some ARP rod bolts, that should put you near 12-1 compression which is good for pump gas
Old Apr 19, 2009 | 02:01 PM
New User
ok is it worth it to run some h-beams on this
Old Apr 19, 2009 | 02:56 PM
stevenDAtegra's Avatar
Rod Bolts are the weakest link. I got my LS Rods shotpeened then the bore for rod bolts bored bigger for ARP Rod Bolts.
P30 Pistons are what I used and will give you a good performance gain plus they fit onto LS rods without modifications.
Old Apr 19, 2009 | 04:28 PM
newtype_33's Avatar
yeap you got the info you need....
Old Apr 19, 2009 | 06:03 PM
New User
thank you so some eagle h-beams with arp bolts will be plenty thanks alot
00trdtaco
Oct 4, 2008 11:54 AM
g0tgot
Aug 30, 2008 10:59 AM
lsvtek
26
Sep 24, 2007 08:01 PM
Mr. Softee
Sep 11, 2003 11:53 PM
