Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
slight problem
Old Apr 19, 2009 | 07:25 AM
hrdsktr1988's Avatar
Default slight problem
hey guys so i just noticed that when i push my clutch all the way in it makes a little click noise that it had not been making and i wonder if anyone has had this problem or if anyone knows how to fix it?? i have an 07 si sedan
Old Apr 19, 2009 | 09:33 AM
nvynuke18's Avatar
Default Re: slight problem
just one click or you mean it the clutch itself is clicking like click...click...click?
Old Apr 20, 2009 | 09:04 AM
miketat594's Avatar
Could be a bad throwout bearing...1 click at bottom normally
Old Apr 20, 2009 | 01:34 PM
yeah its just one click when the clutch peddle is all the way in.
Old Apr 20, 2009 | 03:10 PM
ChargedSI's Avatar
I mine use to do that as well. I sounded like it was in the pedal. I pulled dask cover off under the dash and moved some the wiring harness connections around and made sure the pedal was clear all the way up. I did not see anything hitting the pedal prior to moving things around, but the click stopped.
Old Apr 20, 2009 | 08:57 PM
hondak20z3's Avatar
wtf i have the same problem!!...its only once in a while though...but that clicking noise annoys the crap out of me...i asked a honda technician wat it could be and he told me it might be a spring that is on the clutch pedal...so everytime you push it in the clicking noise you hear is the spring compressing..but idk if thats it..
Old Apr 21, 2009 | 07:50 AM
johnnycivic66's Avatar
I also heard from a little bird that it might possibly have something to do with the rev matching that's part of the drive by wire system.
Old Apr 21, 2009 | 08:23 AM
wow and here i thought i was the only one with the annoying click. well im going to check it out tonight see if its the spring or what.
Old Apr 21, 2009 | 10:36 AM
hondak20z3's Avatar
Well let me know if you find the problem so i can check it out on my car as well
Old Apr 21, 2009 | 06:24 PM
miketat594's Avatar
then kill your lil birdie, cause it's wrong..., check your clutch , cause if a bad bearing is indeed the problem , you can make things much worse...but hey it your cars, not mine..have fun..
Old Apr 22, 2009 | 10:41 AM
jonssonar's Avatar
I had the same problem as well a few months ago. I just pushed the clutch pedal lighter for a while and the clicking went away. I'd just monitor the use of the clutch pedal, it doesn't really have to be mashed into the floor boards to shift gears.
IsitCosIisBlack
Jun 16, 2006 09:49 AM
PoWeRBaN_PaNdA
Nov 29, 2005 05:10 PM
96 ls teg
Sep 5, 2004 10:28 PM
nuport
Feb 12, 2003 09:26 AM
hooptie157
May 10, 2002 02:46 PM
