civic ep3 ride height
Old Apr 18, 2009 | 05:39 PM
ffejufo's Avatar
New User
Default civic ep3 ride height
I just bought the buddy club n+spec suspension and want to know if there should be a difference in ride hieght front to rear if so what should be etc 1/2 higher on the back thanks
Old Apr 18, 2009 | 07:51 PM
DaveSi677's Avatar
Default Re: civic ep3 ride height
well you want the car to leveled when you look at it... if you are doing this yourself well then its whatever looks good to the eye... Might want to get it done professionaly!
but if it was me I would lower it 1.8" front and 1.5" rear...
Old Apr 20, 2009 | 05:52 AM
mustclime's Avatar
Ride hight should be set with the lower control arm angles..your lca's should be slightly angled down from the center of the car......If you have your lca angled up from the center of the car, your rollcenters and below ground level and you have a understeering pig. Setting ride hight by wheel gap is dumb.
Old Apr 21, 2009 | 01:45 PM
DaveSi677's Avatar
Mustclime is correct in his response when setting up for a more performance stance but most ppl don't see it like that... one thing is that these cars you can't really lower more then 1.5-1.8" or else you are asking for big trouble!
DaveF
Jun 3, 2007 04:13 AM
EM1FORLIFE.
Suspension & Brakes
18
May 17, 2006 11:28 AM
SNsLude
Suspension & Brakes
Jan 13, 2005 11:42 AM
S13 slide
Aug 13, 2002 05:58 PM
