97 accord A/C shutting off and on
Old Apr 18, 2009 | 05:02 PM
RhdRicheeee's Avatar
Default 97 accord A/C shutting off and on
97 accord 160k miles
NO cel's
Sometimes when driving the ac will just turn off and about 5 seconds later turn right back on
Its always cold air and doesn't happen all the time
Any idea's?
Thank you
Old Apr 18, 2009 | 05:14 PM
04yfz's Avatar
Default Re: 97 accord A/C shutting off and on
NO cel's
Any idea's?
Thank you
If it happens randomly I would think it's some sort of random wiring/grounding issue. Check connections and ground near the a/c compressor.
Old Apr 19, 2009 | 05:16 PM
19Accord97's Avatar
It could be overcharged or undercharged. You should get it checked out asap before you burn the clutch.
Old Apr 19, 2009 | 07:11 PM
dtapia's Avatar
yes very true or a faulty a/c t/stat or relay.
does the compressor shut off and the fans ? more info would be nice.
Old Apr 20, 2009 | 05:47 AM
ricebike's Avatar
i agree w/ 1997accord's post, but more likely undercharged...
Old Apr 20, 2009 | 12:44 PM
Splitf22's Avatar
Verify the + wire that goes to the compressor. It has a plug and could be cracked taking the heat of the exhaust manifold> It happens on my 94 Accord EX.
Old Apr 26, 2009 | 04:59 AM
rinky9888's Avatar
Take it to your dealer, 97 accords had an ignition recall in 2002, they fixed mine and it hasn't shut off since.
Mark Pammer
Aug 31, 2018 06:16 AM
joshiebdapimp
Jul 14, 2015 02:38 PM
SLCAccord
Apr 20, 2007 05:41 PM
rrkss
Sep 15, 2006 09:16 AM
