how to fix codes..fron the e.c.u..??
Old Apr 18, 2009 | 01:42 PM
lilsicsoul's Avatar
Default how to fix codes..fron the e.c.u..??
ok so i have
CODES
7 TPS - throttle position sensor
and
code 9 CYP - cylinder sensor
number 7 i know how to fix but how do i fix number 9 i went 2 the faqs but the links dont work
Old Apr 18, 2009 | 02:01 PM
lilsicsoul's Avatar
Default Re: how to fix codes..fron the e.c.u..??
Helllppppp!
Old Apr 18, 2009 | 02:07 PM
sixgunsound's Avatar
Number 9 usualy means distributor.
Old Apr 18, 2009 | 03:25 PM
lilsicsoul's Avatar
I know..
and i know thers 3 (sensors?) in ther but im not sure witch 1 to change...
Old Apr 18, 2009 | 05:20 PM
lilsicsoul's Avatar
Old Apr 18, 2009 | 05:54 PM
crxblues's Avatar
did this happen after a mpfi swap?
Old Apr 18, 2009 | 07:05 PM
lilsicsoul's Avatar
it is a mpfi swap... what should i look at?
Old Apr 18, 2009 | 07:57 PM
lilsicsoul's Avatar
Old Apr 18, 2009 | 08:48 PM
linnhatch's Avatar
u usually have to get a new distributor
Old Apr 19, 2009 | 06:40 AM
crxblues's Avatar
yeah u need a dizzy from a mpfi motor. if u already have one and ur getting that code u probably have the cyp wires switched. i forget the colors but its the two wires that you run from the ecu to the dizzy.
Old Apr 19, 2009 | 02:48 PM
ha...tch's Avatar
for code 9 the wire colors are...
blue with green stripe - c1
blue with yellow stripe - c2
these are on the dizzy main plug.
Old Apr 20, 2009 | 10:08 AM
FOMULA91's Avatar
code 7 u need to adjust the TPS to correct voltage.
Nathan_volcom
Oct 21, 2011 05:49 AM
turbob18si
Dec 3, 2006 04:02 PM
Mach69
Feb 19, 2005 08:03 PM
JonGP4
Jul 26, 2003 06:13 AM
xci_ed6
15
Feb 19, 2003 07:32 PM
