Good Crank Pulley????
Old Apr 17, 2009 | 11:38 PM
jspeccrx91's Avatar
Default Good Crank Pulley????
i need a new crank pulley and came across this, anybody try it yet or what yall think about it. was gonna spring for the $400+ fluid but this is only $80.
http://www.dh-racing.com/images/PowerPulley.jpg
Fits ALL Honda / Acura B-Series motors.
This pulley has the ability to absorb vibration, smoothing out your ride
while reducing premature bearing failure and preventing oil pump breakage.
The pulley has a slight under-drive and is lighter than stock, so expect
smoother, quicker acceleration and a gain in horsepower and torque. This
pulley has no effect on alternator charge or battery life, keeping a full
charge just like stock, and works with your stock belts.
*** NOTE *** If your stock pulley is old, has chips or cracks, or
has damaged rubber replace it before it is too late! A crack or chip can
cause your engine to run unbalanced and could come apart at high RPM's.
Available now for only $80.00 + S/H
bretts_crx
Jan 30, 2006 09:51 AM
fe519
Feb 16, 2003 03:41 PM
son-8
Sep 4, 2002 06:33 PM
