rear disk brakes
Old Apr 17, 2009 | 12:57 PM
classdork987654's Avatar
Default rear disk brakes
is there any way you can keep the stock ef trailing arms and just take off the hub and swap over parts off a integra rear disk setup and make it work? the reason i ask is because after doing my conversion i have a really bad toe angle. the alignment shop said it was adjusted all the way out and it still needed to come in a good inch to be straight.
Old Apr 17, 2009 | 01:25 PM
Ermil's Avatar
Default Re: rear disk brakes
You used the wrong compensator arms. Use the EF arms, not the DA ones.
Old Apr 18, 2009 | 03:20 AM
which arm is that, is it the one right above the brakes the highest one up lol does that make any sense sorry
Old Apr 18, 2009 | 05:27 AM
johnnyonth3spot's Avatar
go to this link I used it to do my swap last weekend. There are some good pictures on this site http://fourthgenhatch.net/reardiscswap.html
EF88Ty
Oct 16, 2018 10:33 AM
OnceIwasMuffin
Jun 20, 2018 06:33 AM
SleeiNESS
Feb 4, 2012 08:30 AM
sde780
41
Jan 8, 2012 08:46 AM
chwkef
18
Feb 20, 2009 05:00 PM
