Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Any one have this.
Old Apr 17, 2009 | 10:39 AM
Focal204's Avatar
Default Any one have this.
I saw this on corsport and am very interested on whether it can be used for tuning. Does any one have this or knows more about it?
http://www.corsportusa.com/store/cat...oducts_id=3256
Old Apr 17, 2009 | 10:56 AM
vladd's Avatar
Default Re: Any one have this.
all that it does is change how fast the throttle opens. for example, say right now when the pedal is pressed down 25%, the throttle opens 25% of the way. with that thing, you can make it so when the pedal is pressed 25% of the way down, the throttle will open 50% wide. there's no actual difference in performance when you're flooring it, as you obviously can't go over 100%.
Old Apr 19, 2009 | 08:12 PM
dwojno's Avatar
Will this also work on an 07 ex my guess is it would, i cant imagine the throttle is any different.
Old Apr 20, 2009 | 08:46 AM
miketat594's Avatar
As stated at 100% thats what you have , as for the mid responce , where these cars tend to fail.. More or less in between the shift points where you almost feel a bog in the power, with the booster , you are able to eliminate the hesitation..What it does is overide the sensor to the ECU and makes it feel very sim to a cable activated TB..
I did have some problems with it at certain settings where if the VSA was activated it would cause the cut out to kick in under hard turns, where it had not done this before..If the VSA is turned off no probs and once you learn what will set it off you learn to drive with it on as well..
I give it a 7 out of 10 rating, but nothing is like a cable TB..For $350 it's a big improvement over stock.
yujayn
14
Oct 22, 2009 07:19 PM
Black R
Oct 6, 2008 10:45 PM
RNbuilt
10
Dec 27, 2007 04:04 PM
aZnjCC
11
May 23, 2006 01:39 PM
exquivical
Dec 24, 2001 10:26 AM
