Making your own sway bar?
Old Apr 17, 2009 | 10:38 AM
nico91civic's Avatar
Default Making your own sway bar?
Any one here ever done it?
Old Apr 17, 2009 | 11:18 AM
CW-ITR's Avatar
Default Re: Making your own sway bar?
That is not a good idea at all. Sway bars have to be made with forged steel that can withstand the enormous flexing force of the car's suspension. With coventional household/garage equipments, I doubt that you can make one even if you try. Now, in case you mistakenly meant to say strut-bar, the answer is yes. I have made severals in the past with mostly heavy industrial aluminum.
Old Apr 17, 2009 | 02:45 PM
nope meant sway bar, ive seen a couple that were straight rod with splined arms that attatch to the LCA, i was thinking more along those lines
Old Apr 17, 2009 | 03:48 PM
90_EX_Civic's Avatar
are you serious? forged steel? try stamped steel. a lot of our oem sway bars are hollow tube anyways.
i can't say for sure how thick the the walls are, but if you can you could probably use a solid bar and bend it. the only problem i can see is if you mess up the length. measure twice cut once here. the end links, just drill a hole through it like a oem bar would be, and use the stock oem hardware. or you could go the route of polyurethane.
its posiable.
Old Apr 17, 2009 | 04:17 PM
iskate2's Avatar
2xxx series steel should suffice, and the most important thing is to HAVE IT HEAT TREATED!!! or it will just bend, with no spring-like quality. if you use a high carbon content steel it would more likely break under load. and hollow>solid for many reasons.
with the time and effort required to make one, Id just buy one. theyre pretty cheap.
Old Apr 17, 2009 | 04:35 PM
88Hatchy's Avatar
you could go to a junk yard and measure multiple sway bars, you might find one that is close to the correct dimensions
Old Apr 17, 2009 | 04:44 PM
yeah, they are cheap. and thinking about my last visit to the junk yard. they are all pretty much universal. the only problems i could think of would be the end links, if it wasn't long enough or to short.
the rears would be easier to convert imop. the only problem i would see with the front is if the center section (were the U hump is) would clear your exhaust/cat, and shifter.
Old May 5, 2009 | 09:47 AM
CW-ITR's Avatar
You guys are very helpul so far. Now, answer his question
Charged HB
Suspension & Brakes
Mar 15, 2007 04:22 PM
VSM_EK
Jan 27, 2006 11:05 PM
krazyk
Suspension & Brakes
Apr 12, 2005 01:55 PM
Si Arn
49
May 3, 2004 09:59 PM
ArizSun21
Jan 4, 2003 01:07 PM
