B16 head with a GSR block
Old Apr 17, 2009 | 09:38 AM
calumthestrong's Avatar
Default B16 head with a GSR block
Im getting a B16A3 head for my gsr for going with the poor mans type r. and i was researching it etc. the gsr pistons seem to be the downfall in the way of compression. so is there anything i can do to bump it up a little till i can get some jdm b16 pistons and some other stuff? i know to get a thinner head gasket. but is there anything else? and what intake mani is best. B16 or GSR? thanks guys.
Old Apr 17, 2009 | 09:49 AM
DC_Legacy's Avatar
Default Re: B16 head with a GSR block
If you all ready have a GSR head I wouldnt waste time/money on a poormans R setup. Just swap out your GSR pistons for some ITR or B16 pistons to bump your compression.
Old Apr 17, 2009 | 10:08 AM
C_Rock77's Avatar
LOL...yeah....keep your GS-R head....or there's always milling the head if you're set on using the PR3 casting.
You haven't researched this much, have you?
Old Apr 17, 2009 | 12:16 PM
Rocket's Avatar
Transient response should be better with a stock GSR head vs. stock B16 head, holding all other things equal.
Old Apr 17, 2009 | 04:13 PM
lol. i did research. and im basicly getting paid to get the b16 head. i know its not the best route to go w/o money. but its temporary untill i DO get some. i already was planning on milling it. i just mabye thot there could be somthing else i hadnt thot of.
Old Apr 17, 2009 | 04:37 PM
adam00's Avatar
The gsr intake manifold doesn't bolt on to a b16 head
Old Apr 17, 2009 | 09:20 PM
silverEG6's Avatar
i would do way more research before doing what your doing... b16 head has great flow... but the GSR head has "better" combustion chamber characteristics do some more searching on here im sure you will find out...
Old Apr 18, 2009 | 02:07 PM
haha.. damn i feel like a dumbass with the intake mani thing. i already knew that. idk why i asked.. my bad..
well im pretty sure theres somthing messed up with the current head. the valves are ticking pretty bad. but idk. mabye ill just rebuild the head?
Old Apr 18, 2009 | 02:44 PM
ruffrhyder's Avatar
The valves might just need adjustment, that could be why they are making noise. Swapping to a B16 head just doesn't make sense, even if your are getting it for free or coming up on some extra cash cause you're gonna need to get an intake manifold, new head gasket, seals, etc.
Old Apr 18, 2009 | 02:57 PM
DC_Legacy's Avatar
might just be your LMA's
88 EF Hatch
Nov 27, 2008 06:45 PM
L33TsAbabyEater
Sep 11, 2006 06:53 PM
DC2SIR-G
Oct 18, 2005 02:05 PM
BlueSi2k
Feb 24, 2003 10:32 PM
SSDCRX
Jul 5, 2001 03:08 PM
