1990 Civic TPS wiring colours? Help!
Old Apr 17, 2009 | 09:32 AM
#Leo#'s Avatar
Default 1990 Civic TPS wiring colours? Help!
On my TPS connector there are 3 wires, yellow, green and red. One of them should be constant 5 V, other one constant 0 V and the last one sould be between some minimal voltage and 5 V depending on throttle body position.
I know that yellow one is a constant 5 V (measured it with ignition key ON and engine OFF - pulled out a connector and used multimeter), I need to know which one is a red wire and which one is a green???
Please help!
Old Apr 17, 2009 | 11:39 AM
jlicrx's Avatar
Default Re: 1990 Civic TPS wiring colours? Help!
the red with blue stripe is the signal to the ECU - it should have variable voltage from 0.5 volts at closed throttle to 4.5 volts at wide open throttle
the green with white stripe is ground
the yellow with white stripe is the 5 volt reference signal to the ECU (as you have determined)
Old Apr 17, 2009 | 01:03 PM
#Leo#'s Avatar
Thanks man!!!!
fear45
Jan 8, 2019 12:26 PM
video_voide
Engine Management and Tuning
Mar 31, 2014 02:41 PM
d16rice
Apr 17, 2005 10:51 AM
4thgenHB157
Feb 17, 2005 05:23 PM
Bobby-SiR
Jun 20, 2003 12:03 AM
