recommend turbo for j-series.
That's the 3.5Litre Pilot engine. Are you trying to twin turbo this or single turbo? What is the purpose of the car? what chassis is it going in? what are the goals of the car? Did you want 400-500 on pump gas or race? These specifics are needed in order to help w/ an informed decision.
It's a 04 Honda Odyssey J35a4 (stock) engine with a 6-speed transmission spec stage 3 clutch, its going in a ef chassis vehicle which is set up for drag use. Looking to make 400+ on pump, willing to do race gas but leaning towards pump gas ( want to drive to meets and shows ). Ecu is a motec unit so tuning is not a problem. Lookibg at the new Tial housing 35r, but want other opinions.
Thanks for any input.
Props for doing something a little bit different. You may want to condsider even using an HX40 holset turbo, save you a few bucks (over the garrett GT series and Borg-W) and still get you the numbers your looking for. Other options that are more economy minded could include a small T4 such as the RHC7, or a Garrett To4e. Of course the 362, 35r, an alike will all get you there, just gonna be more expensive, A 62-1 would also be a good choice. Shes gonna be a Tq. monster, hope you got plenty of spare axells....
here is some of the pic from what i did .
the biggest problem is what the stock block can take . we put in 12 1/2 lb into the j32a2 . then the piston wall egg out , did not crack. the turbo we use was for omni performance , which is a dual blade t70 trim cold and t48 hot.we used RDX 410 injectors . they fit good and cleared the intake . unless you run a full standalone we used at the time a AEM FIC to control the fueling of the car.
all posted turbo's will work great. A bw s300, gt35, 6262, even a 6265.. i would use any of those. maybe a gt3076 would work also.
i cant wait to see once people really start tearing in to these motors and a bigger market grows for these motors. theres so much potential for big numbers and easy numbers out of these motors its insane.
wouldnt mind some pics of said car op.
Me: X2 on the above turbos.
