crx eats batteries for fun....
Old Apr 16, 2009 | 07:21 PM
JDMgunmetalCRX's Avatar
Default crx eats batteries for fun....
my crx keeps killing my batteries, its already went thru 4 batteries...
is it my alternator?
when i turn the car on in the mornings or when its been sittin for about 5 minutes the alternator belt squeeks...it goes away after a minute or two.
is the alternator going out or do i need to replace the belt?
Old Apr 16, 2009 | 07:29 PM
crxblues's Avatar
Default Re: crx eats batteries for fun....
im pretty sure you can get the alt tested for free at auto zone, pepboys or advanced atuo
Old Apr 16, 2009 | 07:31 PM
patrickstar's Avatar
this is happening to me too! is ur belt loose? does ur battery charge light on ur cluster ever come on?
Old Apr 16, 2009 | 07:35 PM
my belt is pretty tight. i tightened the crap out of it to get it to stop squeeking. and my battery light doesnt come on when im driving it so thats why im blaming the alternator
Old Apr 16, 2009 | 08:28 PM
mitsubishiv5's Avatar
its so easy to replace the belt, just loosed the alternator bolt and remove, after that if your car still dies, id suggest testing the alternator. it could be a faulty part that may be able to be replaced. My jetta had a bad alternator, fixed it and it never died
Old Apr 16, 2009 | 08:41 PM
jhammond_82's Avatar
Reject Papi
i'm gonna have to agree with the alternator theory.
Old Apr 17, 2009 | 04:34 AM
xaine's Avatar
chaos theory your belt could be out of alignment with the pulleys.
most likely your belt needs changing
i dont think this is the root of your problem.
first you have to test and see if its charging.
you could have a drain on the system.
did you do any electrical type work before this problem started?
to see if there is a drain on the system, or back feed somewhere
make sure everything is off, doors closed, anything that would make any electrical function.
disconnect the negative battery cable.
put a test light between the negative post on battery and the negative cable on the car
if it lights up, there is a drain/ short in the electrical system some where
Old Apr 17, 2009 | 06:35 AM
apekd's Avatar
my problem happend just like this with my last hatch. tightened it way too tight, then the bearings died, then a week later the alt died all together, just replace it and youll be fine
76 camaro car
Jul 1, 2012 07:52 PM
mjrage
Jul 4, 2004 01:06 AM
civisaurusrex
Oct 26, 2003 05:33 PM
wizzards581
Jun 14, 2003 01:41 PM
Old Skool
Mar 13, 2003 10:24 AM
