any diff in calipers? 12 inch rotor
Old Apr 16, 2009 | 05:48 PM
xaine's Avatar
Default any diff in calipers? 12 inch rotor
I have a 90 crx si
i bought a big brake kit for a integra
its the kind that uses the stock caliper by using a braket to move the caliper out
everything fits except,
my caliper is hitting the rotor.
so i am asking if there is a difference with the calipers?
da/ef ? are they the same or different?
i am hoping there is and i can just buy the integra calipers to make this kit work.
thanks again for help
Old Apr 17, 2009 | 04:42 AM
xaine's Avatar
Default Re: any diff in calipers? 12 inch rotor
come on!!
some one has got to know if the 88-81 crx si and 90- 93 integra ls
calipers are different.
Old Apr 17, 2009 | 04:47 AM
Furyof4's Avatar
The steering knuckles are different b/w integra and your civic. The kit will not fit without swapping to 90-91ex or 90-93teg knuckles.
May I ask why are you putting on 12" rotors?
Old Apr 17, 2009 | 07:50 AM
xaine's Avatar
I appreciate the response.
using the 12 inch, mostly for looks, but have ls swap and plan to turbo.
also like running auto cross.
the rotor fits the crx hub.
the brackets fit the crx knuckle.
the bracket fit the crx caliper.
but the caliper is to close and hits the rotor.
i need to know if the caliper is different.
because if the caliper mounts like a half inch more out,
it will work.
so again,,,, is the calipers different or the same?
because if they are the same caliper, then it wont work.
Old Apr 17, 2009 | 08:34 AM
Furyof4's Avatar
The teg caliper and knuckle are different from your civic. The caliper mounting is spaced farther out to accommodate the 10.2" rotors. So if the kit is made to fit a teg caliper and knuckle then thats what you need to make it fit.
PS. You DONOT need 12" brakes for autox. Stock size are usually enough.
Old Apr 17, 2009 | 12:19 PM
xaine's Avatar
well , thanks for the help.
the crx caliper may be diferent but they do bolt up to the integra knuckles
i may not need 12 inch, but i have my reasons
91CR-XSiR
Jul 25, 2007 11:03 AM
Cowiebunga
May 26, 2005 05:09 PM
Gonzo_SiR
Mar 10, 2004 06:55 PM
litlekikr
11
Nov 17, 2003 07:24 PM
kahren
Oct 5, 2001 11:19 AM
