speedo not working!!!
Old Apr 16, 2009 | 05:41 PM
getblown01's Avatar
Default speedo not working!!!
hey guys, i bought a si cluster for my 94 coupe,installed it and everything was working fine. i noticed today that as i was driving the speedo needle started to twitch back and forth a little. i didnt pay it no mind until later on when i got on the gas and vtec kicked in, the needle wrapped all around to 0 and wont go back! any suggestions would be greatly appreciated.
Old Apr 16, 2009 | 06:00 PM
getblown01's Avatar
Default Re: speedo not working!!!
anybody?
Old Apr 16, 2009 | 06:29 PM
shietzitzkien's Avatar
check your ground?
Old Apr 16, 2009 | 06:53 PM
daluv's Avatar
Check/Clean your VSS. Sometimes the connectors get a little dirty and can cause the signal to become lost.
Old Apr 16, 2009 | 08:58 PM
getblown01's Avatar
vss? sorry guys, im alittle new to the honda scene, so im not fluent with the lingo.
Old Apr 16, 2009 | 09:00 PM
sp00ledbseries's Avatar
vehicle speed sensor. google D series VSS
Old Apr 17, 2009 | 12:57 PM
daluv's Avatar
Like sp00led said, the VSS is the Vehicle Speed Sensor. Its a geared-sensor that goes into the transmission.
Its located where your passenger side axle enters the transmission on the top of the transmission, almost straight below your throttlebody and intake, and behind the starter, in that area. There is a 3-wire plug that connects to it, and 1 10mm bolt that holds it in. Unplug it, take the bolt out, take the VSS out (usually requires some twisting back and forth, but twist it by the metal base, not the plastic part where the plug is,) then spray the plug connector (a black plastic piece on top of the VSS) with some Electronics cleaner, and spray the grey plug as well. Then install it back in and see if that does the trick.
Chrizcrozz
Aug 31, 2011 09:33 PM
aziaticvang
Jan 13, 2008 06:35 PM
bsmith628
11
Aug 3, 2007 01:58 PM
rerun07
Dec 8, 2005 08:21 AM
aws140
Aug 17, 2005 07:08 PM
