Car not starting please help :(
Old Apr 16, 2009 | 05:03 PM
UnforgivingEK9's Avatar
Default Car not starting please help :(
can someone point me in the right direction please I understand that this is vague but here is what I have
97 ek accessories will not come on nor will the starter turn or even register BUT the lights still work? Ive had a problem like this before and had to replace the big huge 40A fuse before under the hood
I was wondering if this could be the same problem? And if so can the lights still work?
Thank you in advanced
Old Apr 16, 2009 | 05:29 PM
civic_driver's Avatar
Default Re: Car not starting please help :(
Does the starter click when you switch to ON on the ignition switch or is there no sound? If there's no sound then it's probably a burned fuse. Otherwise, it might be a bad starter.
Old Apr 16, 2009 | 05:33 PM
Nope not a bad starter just did a jimmy rig test and arched the power to see if the starter works and it does just no gas and NO the starter does not click when I turn it on thank you though
Old Apr 16, 2009 | 05:41 PM
It's probably a burned fuse. Not sure which one exactly as I haven't worked on a honda in a while but maybe someone can chime in and tell you exactly what to check.
Old Apr 16, 2009 | 05:52 PM
Im thinking its the 40A fuse under the hood thats my guess I did recall some info from last time I used my car when I was engaging my fuel cut off switch I heard an arc as if there was loose wires which I just now replaced
*waiting for a ride to autozone to replace 40A fuse*
any other suggestions would help a lot just in case I might have missed something
Old Apr 16, 2009 | 06:49 PM
HondaGuy951's Avatar
it's the 40A relay Lance! LoL
Old Apr 16, 2009 | 07:24 PM
It was the 40A relay
Old Apr 16, 2009 | 08:46 PM
scrhdeg6's Avatar
need a smog! and cant pass i can help!!!!!!!!!!!!!!pm me
Teggerson
Oct 23, 2020 12:36 PM
azandford
10
Jul 1, 2017 05:39 PM
Hondaacc95
Apr 26, 2010 10:34 AM
lledcomp
Apr 4, 2007 08:27 AM
zhan28
Mar 8, 2006 04:54 PM
