help me please
right my honda the left indicator stays on, the only way i can stop it from being on is disconnect the battery :S:S
anyone no i have check the fuses and all and the relay it seems fine when i take on the fuse for it, it still stays on? and when i put the hazards on both sides just stay on they dont flash??
help?
its all disconnected so it doesnt drain the battery but then my alarm and immobileser isnt connected i want to get it sorted tonight! please help
help?
turn signal flasher, either that or you've got a bad multi-function switch, try the turn signal flasher first, you will find it in the fuse block under the knee bolster, it will look like a relay.
ive checked the relay it even stays on when the car is locked and no key in ignition :S it fixed itself today but then my alarm went off today and its on again!! so i recon its summit to do with the alarm. JOY!
Larry_Civic
Honda Civic (2001 - 2005)
May 5, 2018 09:09 AM
