Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
D17A1 vs D17A2
Old Apr 16, 2009 | 09:17 AM
Tomsecks's Avatar
Default D17A1 vs D17A2
I know the power ratings are only about 10 HP difference from the factory, and that the A2 is the VTEC engine. Are the gains worth swaping one for the other? I have one of each, both are good, not sure if it's worth the time to swap or not. How bad is the wiring? Just a simple ECU swap?
Old Apr 16, 2009 | 10:02 AM
skipbarber's Avatar
Default Re: D17A1 vs D17A2
engine harness, ecu and key reflash. if you have them or can get them cheap, go for it. otherwise you'll see more gains from dropping the A2 head on the A1 block and running a vtec controller. take it from me. im running what i call a D17A1.5 because im running a stock A1 block and an A2 head with the EGR deleted and manage it all with a hondata kpro, so i wired the vtec, vtec pressure like stock and converted my primary o2 sensor to a wideband primary AFR sensor based on the HX or 04-05 civic wiring.
Old Apr 16, 2009 | 12:33 PM
toyomatt84's Avatar
Sanji
Look in the FAQ's before posting next time: https://honda-tech.com/forums/showthread.php?t=2247386
Panzo274
Apr 24, 2017 09:18 PM
redrix
Apr 21, 2013 01:06 AM
dc4teg95
Nov 22, 2006 11:22 AM
RagingAngel
Sep 25, 2004 03:49 PM
powerslide360
May 20, 2004 01:21 PM
