LSVTEC bogging/sputter problem
Old Apr 15, 2009 | 05:11 PM
MonKK's Avatar
Default LSVTEC bogging/sputter problem
Have a EF hatch with JDM b16 head/ls block. Running a PW0. No CEL, idles fine but when moving the car bogs like crazy and sputter like crazy. Just changed the spark plugs but still does it. Anyone have any suggestion.
Old Apr 15, 2009 | 05:47 PM
SIkilla's Avatar
Default Re: LSVTEC bogging/sputter problem
distributer?
Old Apr 15, 2009 | 05:49 PM
tony7626's Avatar
check your timing.
not just your belt.
get a timing gun and check the dizzy timing.
Old Apr 16, 2009 | 07:30 AM
MonKK's Avatar
Timing is right. Car runs perfect when it cold and barely warming up but then after it warms up completely it starts to bogg and sputter. Distributor? Cap? rotor? Wires?
Old Apr 17, 2009 | 07:24 AM
tony7626's Avatar
any smoke from exhaust? or moisture from your tail pipe?, if there is it may be that you have a bad head gasket...and when you drive it the cylinders fill with coolant, then after sitting the coolant leaks out and/or evaporates so it then runs fine again. any compression numbers?
Old Apr 17, 2009 | 08:02 AM
1sickef9's Avatar
step 1 Find Wine Bottle
step 2 Fill wine bottle half up with any kind of fuel (Diesel Prefferably)
step 3 insert any kind of rag(Cotton Prefferably)
step 4 light rag with a lighter
step 5 throw at Ls/Vtec
step 6 get new motor that will be reliable
hatchyboy89
10
Jul 17, 2012 02:19 PM
pimpwagon
Nov 12, 2010 08:41 AM
88 EF Hatch
Sep 22, 2009 10:38 AM
bebe101
Nov 21, 2008 05:32 PM
SiLuck2
Sep 1, 2006 04:56 AM
