Suspension & Brakes Theory, alignment, spring rates....
Tokico Illumina
Old Apr 15, 2009 | 05:09 PM
Duc_du's Avatar
Default Tokico Illumina
i found a set of these on craiglists. He said it has 10,000 miles on them and selling it for 220 just for the strut. DO you think i should grab it? i thought the price was low and not sure if its missing anything. what is the brown thing on top of the strut?? the two front struts is missing them. I think it also missing the 2 gold thing that go below the strut. thanks in advance
Old Apr 15, 2009 | 05:18 PM
bakertime's Avatar
Default Re: Tokico Illumina
I rum them on my Integra and haven't had any complaints. They go new for $100 each, so that's not a bad deal. i think the brown thing you're referring to is the bump stop. The only thing I could see missing are the bushings where it mounts up top, but you can reuse the stock parts for that.
Old Apr 15, 2009 | 05:36 PM
Duc_du's Avatar
what about those 2 gold thing that goes at the bottom? do i need them?
Old Apr 15, 2009 | 06:37 PM
stevieteg's Avatar
I have no idea what those are. Mine did not come with those brackets and I don't know what you would need them for.
Old Apr 16, 2009 | 02:29 AM
patrickstar's Avatar
those two gold things are to secure your brake lines. it bolts onto the shock body and lets the brake line safely wrap around it. if you have them on ur current suspension, you dont need them.
Old Apr 16, 2009 | 06:38 AM
stevieteg's Avatar
Are you sure?
The Illumina's have the brake bracket already on the shock. It looks like that picture is for a different application and not the 92-95 civic/94-01 integra one. Where the lca goes on the rear looks awfully wide and the front brake bracket looks different.
Old Apr 16, 2009 | 07:42 AM
Duc_du's Avatar
oh oaky thanks for all the feedback. i will check my current suspension today. the lugnut is so hard i couldnt take it off the other day....
Old Apr 16, 2009 | 08:02 AM
Tyson's Avatar
dont buy those used. especially just for the shocks. look at how low he set the ride.
$220 is not a good deal for these.
the brake line bracket is for 89-91 cars. 88 has a slightly different brake line bracket. thats all. no big deal.
Old Apr 16, 2009 | 08:22 AM
Duc_du's Avatar
i decided not to buy them now.
Old Apr 16, 2009 | 09:00 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Yea it also looks like the rear shock forks are BENT to fit them on 96-00 Civic rear LCA's, instead of using the proper spacers.
Old Apr 20, 2009 | 05:41 PM
bakertime's Avatar
Wow good catch Patrick...
Old Apr 20, 2009 | 06:03 PM
batallic's Avatar
EGSRuppeal
Suspension & Brakes
Dec 31, 2008 08:41 AM
Infamax
Paint and Body
21
Oct 16, 2007 01:36 PM
Mavrick
Dec 1, 2006 09:05 PM
prostreetonline
30
Jul 30, 2006 06:28 PM
streetlights
Dec 5, 2003 05:20 PM
