2001 F23 5M - Which transmissions bolt up?
I know the H22 does, what about the H23, F22, etc.
Transmission just **** (5-speed) and I'm shopping for a new transmission, and I'm having a hard time finding one for the engine code "F23" alone, but I find plenty for the F22, H22, and H23 or w/e. Will they bolt up with NO mods??
Thanks guys.
Thanks guys.
trans will bolt to the block.
should be no issue with the shifter, i can't say for sure off the top of my head that the axles will work. the trans mount may need some thinking through.
the only other thing i can think of is that the speed sensors are different. you may need to retain your original one and put that in the f22 trans, or maybe the connector is the same and you can just plug in the f22 sensor.
i'm familiar with most accord models... but i havn't spent enough time trying to interchange parts, just keeping them running. but you've got a list here of things you'll need to confirm before getting your f22 trans.
hondaprelude830
Feb 23, 2008 07:45 PM
