Is this an stock ITR exhaust system?
I purchased a used ITR that had an aftermarket exhaust system. I'm looking to put back the stock exhaust and I found a used one for $80. I just snapped a picture and need to confirm before I buy it. Looks a little longer than my aftermarket.
Could it be for a sedan?
Are all Integra axle back the same size?
So by these pictures...oem ITR?
Wow lucky find. I've been trying to find a ITR muffler for my car. The ITR should have bigger piping. 2.25" I believe. It's a direct bolt on for 00-01 GSR's I believe. The others need a bit of modifying. Someone correct me if I am wrong.
"A major contributor to the Type R's ability to generate 195 horsepower from only 1.8 liters displacement is its highly efficient exhaust system. The exhaust flow rate has been increased by 30 percent over the Integra GS-R model thanks to a number of improvements. Starting with a large-diameter Tri-Y header system, the individual head pipes gently converge into a tapered collector to provide smooth flow with minimum obstruction. The stainless steel header connects to an exhaust system with significantly increased pipe diameters, the addition of a third exhaust chamber, and a performance-oriented muffler with a large NSX-style exhaust tip. "
B18Redline
Dec 24, 2004 09:29 PM
