Del sol aux lights stay on with highbeams..
So i just got my h.i.d's installed and the installer at this shop did them different then normal because i guesss they had the wrong bulbs but made it work . So to activate my h.i.d's i have to turn on my highbeams and with the del sol the aux lights go away when activating the highbeams..i was wondering if theres a way to keep aux lights on with highbeams? is there a way to mod it?
i read a post about rewireing the aux lights to jus haveing the aux lights on without the lights on..would those same steps work?
someone help me plz
someone help me plz
yes, those same steps would work. I did it.
I know what you mean though... the AUX lights help a ton with lighting up the ground in front of you while the high beams are shining way ahead.
By AUX lights do you mean foglights/driving lights? Because the foglights are supposed to turn off when you hit the highbeams on USDM models. On JDM models they stay on.
You know how to turn on the aux lights, you have to have the low beams on? Well the rewiring mod he speaks of makes it so all you have to have is the corner lights on. As a result, any time the headlight switch is turned on, whether it be to parking lights, low beams, or high beams, the AUX lights will work if the AUX light switch is on.
That's how I can do this:
eclaire
Mar 6, 2009 11:06 AM
dohcVTECeg2
Apr 10, 2005 01:24 PM
